July 14, 201411 yr I did already swap ej22 egine into GL. But I have gl radiator but need to know what shape to look like upper and lower hose fix to ej22 Thanks.
July 14, 201411 yr if one outlet/inlet is smaller you can cut a section of the smaller hose and use it as an adapter for the larger hose.
July 17, 201411 yr Author Like to photo... Just like to get idea. Thanks Edited July 17, 201411 yr by Suba_GL_87
July 19, 201411 yr I used a flex hose with built in spring for the bottom hose and it's worked great so far, i got it from advance auto.
