EA82T knock control modules
there is a few of them...
only in use in the 3 plug ECU flapper afm, 2 wire knock sensor Series One 85,86MY
different mounting brackets for starters - between the XT and the sedans and wagons.
XT is mounted above the transmission tunnel behind the ash tray with fuel and ignition relays
Sedan is mounted beside the glove compartment against the a pillar base
The US RX version is different from the Australian market auto version of the GLTA EA82T 3 speed 4WD auto.
Not sure yet if the RX and the GLTA AUDM got same or different yet.
The plastic pin plugs have a number printed in black on them to correspond the KCM number just a 23 or a 25 in black
The mounting brackets also have that same number stamped into them.
KCM23C AUDM GLTA sedan 3 speed auto4WD
KCM24  USDM guessing 5PT 4WD  RX
KCM25  AUDM Vortex XT turbo 5 speed FWD - yellow label
I think the US item is different having an altitude wire.Or ours different for not having it :)
Does anyone know much about these? Ivansimports maybe ? There is very little in the factory manuals.
Parts books may help. Must go look in there
Edited by jono
then, there is this one, by Denso
no claim to be a knock control module at all, is in black plastic box, one extra pin and sold to me over the internet. I was expecting same metal box and part number I had before. Silly me did not ask I suppose :(
I suspect it may be NZ DM or maybe that part number looks more EA81 stuff. Maybe it is EA81T ?
