2004 forester high rpm when in Neutral
Hi,
I have a 2004 forester standard, recently when I change gear if I am in neutral the rpm goes high 3000 unless I am in gear and my foot is off the clutch. Also I have an Evap leak check engine light. Any suggestions.
I cleaned up the throttle body and the IAC valve and the air filter. I have a small exhaust leak, I don't that is what causing the problem.
Need help Please.
Welcome to the USMB.  You found a great site--but you're in the wrong place!
Please start a new thread in the "New Generation Forum" and post your questions there.  Thanks.
