August 28, 201411 yr I have, to this point, had pleasurable times wrenching on my Wifes new (2003) Forester 2.5. Front sensor went in with ease.cured code for 5 min (front heater) then set code for rear heater. get ND sensor, jack up look for sensor, where did they hide this thing? thanx
August 28, 201411 yr Top of the second cat back just past the trans. It sticks up toward the left side of the car. You can follow the wiring for it down the left side of the trans. The connector has a tab that sticks it to the side of the trans just above the rear trans cross-member.
August 28, 201411 yr https://www.google.com/search?q=03+forester+o2+sensor&safe=off&client=safari&hl=en&source=lnms&tbm=isch&sa=X&ei=2mX_U7OOBJT7oQSVroDACQ&ved=0CAgQ_AUoAg&biw=320&bih=356#facrc=_&imgrc=iQGHo1iMeaIujM%253A%3BowlbTDgx6TsoTM%3Bhttp%253A%252F%252Frepairguide.autozone.com%252Fznetrgs%252Frepair_guide_content%252Fen_us%252Fimages%252F0996b43f%252F80%252F20%252F47%252F10%252Fmedium%252F0996b43f80204710.gif%3Bhttp%253A%252F%252Fwww.autozone.com%252Fautozone%252Frepairguides%252FSubaru-Forester-1998-05%252FComponent-Locations%252FHeated-Oxygen-Sensor-H02S%252F_%252FP-0996b43f8037f2b2%3B500%3B272
