EA-82 Heads
Quick question...
Are EA-82 Carburated and SPFI heads the same? If you change the intake manifold and disty, can you convert a SPFI EA-82 to carburated easily?
the inlet manifold bolt pattern is the same, if that is what you need to know. I have an spfi inlet bolted up to EA81 carb heads
Carbed heads have ports for Air Suction Valve tubes at the bottom on the side of the Exhaust outlet.
You can drill and tap if needed or just delete the ASV system if leaving carbed.
