I have noticed that there are 'torque converter repair sleeves' as well as the 'input shaft repair sleeves'? How would someone install one of those? I can see sleeving something if you are able to machine it first. But there is no real info on the parts, just that they exist.
Yeah I assume these sleeves are really thin sheet metal (like the Speedi-Sleeve), meant to restore the sealing surface when it's worn or damaged. They just press over the original surface with a bit of bearing retainer adhesive. They're thin enough that the seal still works fine (maybe a bit tighter).
I can understand the torque converter, because it has a large seal in the front diff housing. But the input shaft I'm not so sure, it just has a static o-ring. The input shaft does have a couple wear surfaces against some bronze bushings, but if this were worn out the bushings would wear faster and be the replacement item.
