October 12, 201411 yr Hi Guys, After all reading and understanding about how to lift my car, I decided to do it by my self. My car : 2006 Impreza SW, 2.0L, 4WD (euro model). I took my measurements from front and rear strut mounts and they are precise and fit my car perfectly. The spacers fabricated from 6061 Aluminium. Attached my drawing in PDF. I also have it in X_T and Solidworks but I cant share it here. Enjoy, Arik Arik Front Spacer.PDF Arik Rear Spacer.PDF
October 12, 201411 yr Author https://plus.google.com/photos/100523733524619562126/albums/6068690722564996849 The photo gallery.
October 13, 201411 yr Nice clean drawings! If I see it correctly, this is how you fastened the new spacers to the top of the struts: - drill out the 3 old studs from the top of the struts; - screw-in 3 M8 screws (threaded on their full length) from the underside of the strut, into the bottom of the new spacer, and tighten-up; - then insert the exposed ends of the 3 new M8 screws into the car, as normal. Is that what you did?
October 13, 201411 yr Author Yes, this is what I did. You don't need to drill the studs, just push them. The screws are fully threaded, 60mm length, 8.8 grade. I used high strength locktite to secure the bolts in place so they don't get lose when tightening the nuts on the car.
