October 31, 201411 yr Can the nose cone off a 93 2wd impreza on to a 93 awd lego tranny i seach and googled with out any esalts at all. So any one els come acrost a need to swap these?
November 1, 201411 yr I *think* the 1990-early 94 FWD trans is different. If you found a late 94 or 95 FWD impreza transmission it *might*. Easier way to convert awd to fwd is a spool and blocking plate.Like these: (cheaper ones can be found/fabricated if you look hard enough)http://www.bremarauto.com/products/subaru-2wd-conversion-kit/http://www.subarugears.com/Products.html Edited November 1, 201411 yr by Ibreakstuff
November 1, 201411 yr yes it should work but your going to have to swap hard parts to make it work ie reduction drive and redution drivin gear.
