November 17, 201411 yr Does anyone have a interchange part # for the rubber bushing in the rear center diff. mount on a 92 LOYALE with 4wd but not fulltime 4wd or possibly a new mount ? Any remanufacture sources for this mount out there any help will be appreciated Thank You Tim
November 17, 201411 yr It was not available from my local dealers so I ended up making my own by injecting some 3M window weld into the old bushing and letting it cure a couple days.
November 18, 201411 yr Is this the one on top of the snout of the rear diff? I bought one from the dealer last year and there were a couple left in the country but they were over $100. Super Pro makes a polyurethane replacement but like it was said, some polyurethane window weld will work if injected into the slots on the old bushing.
