removing the instrument cluster
how hard is it to get the cluster out from my 95 legacy wagon? i want to remove the abs light
Pretty easy.  I was just digging around one a few weeks ago as I got a fog light switch from a yard car.
I think it was four screws to remove the bezel (two up inside and two on the lower edge).  A few screws around the cluster (two up top again, two and lower corners).  You can then pull it out a bit to get at the connectors (just squeeze and pull in the middle).
See some pics here that give you an idea. Also
at the 5:22 mark.
so does the wheel have to come off or will it wiggle out between the wheel and dash?
Steering wheel does not need to be removed.  It is a little tight, but keep wiggling and the cluster bezel comes out (that is a tighter fit with the steering wheel compared to the cluster itself).
