Replacing Transmission seals for 4 speed dual range
Putting a new used transmission in my hatch, I have new seals for input shaft, rear drive shaft and both side stubs, I figured I would replace all seals on the new trans before I install, but don't know if I should mess with the input shaft, it's harder to get to than the others, and I don't know if they are a common problem anyway. The trans has been sitting indoors with no gear oil in it for a few years, what do you think?
Hi This is Jerry, my question to you is why the 5 speed is so much better trans. I make a kit so everything remains stock inside of your car, if you install a 5 speed in your hatch you will tell yourself why i didn't do this years ago. Thanks Jerry
Input seal requires splitting the case......very difficult on a 4spd.
replace all the others.
And then get a 5spd when the 4spd craps out.
Dude, if that's the red hatch, it DESERVES a 5 speed! :)
Installing a D/R 5 speed into my 84 turbo wagon is one of the best modifications I will ever do to that car, what a difference! :D
I didn't realize the case needed to be split! I thought you could pop that plate off that's in front of the front seal, but anyway I did just that, replaced the other 3 and call it good.
regarding 5 speeds, Im well aware of the benefits of a 5 speed swap, I'll take your comments as re-enforcement of that.
