car stalling
Hi guys I just purchased a 96 legacy l for some reason when I take right turns with a little speed my car boggs out some times it dies sometimes it barely idles then 10 seconds later it fine but only right turn I don't get it and it's not throwing any codes any help would be appreciated
Hmmm. Mine sputters occasionally if its under 1/4 tank and I go around a long right curve like a cloverleaf exit/entrance ramp.
If you drive tight circles in a parking lot (big, wide-open parking lot) will it stumble?
It only does it when turning right? Or will it do it if you turn left as well?
I had the same problem in a 98 Forester and it ended up being valve shims that were worn causing back pressure into the EGR system and eventually stalling at idle. I don't know if the 96 Leg uses the same system or not
  • 1 month later...
Only when I turn right and yesterday I managed to run out of gas at 1/4 of a tank so I truly believe it's gotta have something to do with my gas tank
