March 29, 201511 yr i gave my mother this car a few years back and want to make sure she is keeping up with the maintenance, does anyone have anywhere to download the owners manual in a pdf? and does the owners manual list the recommeneded mileage on changing filters/fluids/packing bearings etc? or did this come in a different pamphlet? also what is general costs at an indie to have the timing belt repalced on this car? think it is probably due thank you
March 29, 201511 yr T-belt, idler pulleys, cam and crank seal and reseal the oil pump all due at 105K It's about $250 in parts + labor. The Gates Kits on amazon are good. You can go to a Subaru Dealer and have them pull the maintenance records for any work that has been done at a dealer and if you register the VIN with them in your name they will send you maintenance reminders.
March 29, 201511 yr Author ccr built this motor for me 7-8 years ago i checked with them and evidently i have the 60,000 mile timing belt so it is definitely due, my mother does not drive the car much so that is good, but sure it has hit 60,000 by now i did all fluid changes on it 3 years ago and am guessing she has put 25,000-30,000 on it since then took it to subi works in phoenix for fluid changes and they did some of them, for some reason did not do others... but it will go back this week for the timing belt and will have them do the other fluids need the recommended change intervals for all fluids spark plugs/wires, repacking bearings, any other adjustments etc i have been running all diesels now for a while and i dont even remember everything she needs to be doing to this car, totally forgot the timing belt until last night
