April 7, 201510 yr How does the bulb come out of the shift lever indicator in the center console? I have the surround off but removing the indicator seems to be rather complicated. I see two blue wires going into the indicator and they seem to be attached to a socket. However I cannot seem to get the socket out. I can't tell if it just pulls out or if it twists. It is plastic so I don't want to force it and break it. Any advice would be appreciated. Thanks.
April 7, 201510 yr mrwl8agn, Any time you post a question about your particular automotive problem, in order to give you a correct response, we need to know the year and model of your car. And if its mechanical in nature, the mileage and options of the car (4 or 6 cylinder, manual or automatic etc.) is helpful as well. You can appreciate that each generation of car and model is different. So, what have you got?
