April 14, 201510 yr The 110,000 mile service interval is due on our 2006 Outback 2.5. I presume there is a kit that includes belts and all the tensioners/rollers. I plan to change the water pump while I'm at it. Are there different styles of water pump gaskets? Impellers plastic or metal- you know, that sort of thing. Is there a preferred kit and water pump I should be looking at, or should I base this on price alone?
April 14, 201510 yr Gates kits on Amazon are $130 for everything timing copmonent related. Subaru OEM water pump gasket. Reseal the oil pump and tighern the backing plate screws - one or more are often loose.
