Need help identifying these plugs ASAP
So I just swapped in an 02 ej25 into my buddies forester and can not for the life of me figure out where these go. Car starts and drives btw
051F8BBB-C0F1-43A2-A0BC-E815B01772F0_zps
16198D9E-E86F-4577-9C57-B0D57F98EE25_zps
Intake is the original 99 intake so there aren't any new wires or connectors
Grey one is the front o2 sensor.
White one looks like the ECT sensor. Sensor is in the coolant pipe on top of the block. Look down just in front of the PCV hose that comes out of the block.
And if you check codes (A $10 harbor freight code reader will do) and those are the correct plugs it will be throwing codes for both of them. :)
