1996 Subaru Outback...
When I remove cango carpet and fuel pump cover remove too.. I can hear when key on but I was did remove fuel line hose but won't fuel comin out.. Any idea why fuel pump won't work.. I did replaced new fuel pump from rockauto.
If there is fuel in the tank, and the pump is running but nothing coming out, pull the unit out of the tank and make sure the pump itself is still connected to the outlet tube.   Also, some models (not sure if 96 is one) have a "pulse damper" on the fuel pump module.  The cap can come loose causing the fuel to flow back into the tank instead of out the line.
