ragingbull Posted June 12, 2015 Share Posted June 12, 2015 I did the lift months ago and still can't figure out the best way to fix my 4x4 shifter. I heard bending the clutch shifter isn't the best thing to do.. The reason why it's disconnected is that after I did the lift the 4x4 shifter was in the way of the clutch shifter when I tried to reverse. Your advice and expertise is always appreciated! Here's a pic! Quote Link to comment Share on other sites More sharing options...
ragingbull Posted June 25, 2015 Author Share Posted June 25, 2015 Any ideas anyone? Quote Link to comment Share on other sites More sharing options...
Dinky26 Posted June 25, 2015 Share Posted June 25, 2015 Having a hard time seeing what your problem is here. Maybe you can add another picture, not really seeing an issue after lifting, shouldn't really change the dinamics, mind you I have not lifted one before. Quote Link to comment Share on other sites More sharing options...
ragingbull Posted June 25, 2015 Author Share Posted June 25, 2015 The 4x4 shifter is in the proper position. The gear shifter is in neutral in the pic. When you try to shift to reverse the 4x4 shifter is blocking the gear shifter. Quote Link to comment Share on other sites More sharing options...
Dinky26 Posted June 25, 2015 Share Posted June 25, 2015 I'm guessing the bar with a nut and threads is what is becoming in the way(red arrow) still not sure how that is the 4X4 selector. Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted June 25, 2015 Share Posted June 25, 2015 Heat it up with the torch and bend it where it needs to go (off the car). It will also probably need to be extended too. Quote Link to comment Share on other sites More sharing options...
