alxborg Posted May 26, 2004 Share Posted May 26, 2004 With help from my son, we thought we had all marks lined up- when I turned the engine over there were no clunks but it clearly is out of wack. There is not a good illustration in my book to go by. I assume that if there were an internal collision it would make a noise- safe assumption? Any ideas to get this motor happy again would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
99obw Posted May 26, 2004 Share Posted May 26, 2004 What manual are you using? Whether it be Haynes or the FSM it should all be there. Make sure the cam marks line up and the crank sprocket lines up with the mark on the oil pump. If you use an OEM belt the marks on the belt should line up with the cam and crank sprocket marks. Quote Link to comment Share on other sites More sharing options...
alxborg Posted May 26, 2004 Author Share Posted May 26, 2004 using Chilton manual. someone sent a great link of a subaru manual. Thanks. alxborg Quote Link to comment Share on other sites More sharing options...
theotherskip Posted May 27, 2004 Share Posted May 27, 2004 also note that the timing mark on the crank sprocket is a line on one of the lobes in the back of the gear, and not the triangle in the center... Quote Link to comment Share on other sites More sharing options...
toddkageals Posted June 2, 2004 Share Posted June 2, 2004 using Chilton manual. someone sent a great link of a subaru manual. Thanks. Could you send me that link? I'm looking for some info. to help me change a head gasket. Thanks, Todd alxborg Quote Link to comment Share on other sites More sharing options...
