Ea71 to ea81 motor swap for a brat
Does any one know if you can put a ea81 in a ea71 buddy of mine and I can seem to find a swap any were
  • 2 months later...
Well... No, an EA81 will not bolt right up if you have an early EA71 with a top mount starter/gearbox.
If you have a later side mount starter EA71 or are using the EA81 gearbox then yes, bolt away.
Leeroy is correct about the ea81 not mounting to the top Mount starter transmission.
I just did this swap over the weekend and had to use the ea81 transmission because they do not line up.
Also depending on what type and year ea71 car you have there is a couple other little things that need to be changed.
