August 4, 201510 yr Got these digital gauges for oil pressure and water temp for my ej22 swap. wondering where to connect each sender unit. Using the EJ radiator if that helps. Anyone done anything similar?
August 4, 201510 yr Author did some research, apparently the subaru is 1/8 British national pipe thread and the sender is 1/8 npt. wondering if its the same case for the water temp sender. cant find much on that
