EA81 brake caliper parts needed .....
and Rock don't list them from my searches.
Does anyone have any other suggestions ?
Subaru in the motherlkand is also coming up NLA
below is a non genuine part on a reco caliper I got from Rock, so someone made them once ...
"guide pin boot" is one with metal insert support tab also NLA
and below is the "lock pin boot"
these NLA could be the downfall of EA81 Series :(
looking at differences between EA81 and EA82 calipers
EA81 guide pins 14mm uses bonded metal "dowels" as called in manual to secure
EA82 guide pins 16mm uses a simple expand boot over a  "hob" to secure
EA81 lock pin boot holes in caliper 16mm ID where the double concertina boot fits through to do both sides of mount
EA82 lock pin boot holes in caliper 18mm ID  ^^^^^^ what he said ^^^^
so, even if you could make an EA82 boot fit, will be loose due to smaller guide pin diameters
Edited by jono
Wait till you get an 82 or earlier...Different set up completely.
