Pacosquared Posted October 14, 2015 Share Posted October 14, 2015 I have changed out the timing belt along with idler pulley, tensioner and the water pump. The car wants to overheat when I drive it. Nothing in the oil. No white smoke. I lifted the front of the car and did the squeeze and fill method to get air out of the system. I put the radiator cap on because it started to overflow and then when I checked it with it off the top and bottom hose was caved in. I took of the radiator cap and they went back to normal. Any ideas? I am going to take out the new thermostat and try the boil test. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted October 15, 2015 Share Posted October 15, 2015 (edited) do a search, "how to fill and burp your cooling system" your cooling system is not full. did you remove the vent plug when you were filling the system. did you replace the t-stat? if yes, was it a subaru part from the dealer? Edited October 15, 2015 by johnceggleston Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 15, 2015 Share Posted October 15, 2015 (edited) There's still air in the system. There should be a bleed screw on the top corner of the radiator opposite the cap. Remove that and slowly add coolant until it starts coming out of the opening. Then put the screw back, and top off if necessary. Fill the overflow bottle to the max/full mark. If there's no screw, pop the upper hose loose from theradiator and pour coolant straight into the block through the hose. When its full up, put the hose back and top of the radiator. Cap the radiator, idle the engine until the radiator fans cycle on and back off. Then turn off the engine and let it cool for about an hour. Recheck coolant level after the engine has cooled. Edited October 15, 2015 by Fairtax4me Quote Link to comment Share on other sites More sharing options...
Pacosquared Posted October 15, 2015 Author Share Posted October 15, 2015 Thank you I will try these. Quote Link to comment Share on other sites More sharing options...
Pacosquared Posted October 15, 2015 Author Share Posted October 15, 2015 Wow nailed it guys. Worked perfectly! Thank you. Quote Link to comment Share on other sites More sharing options...
