November 22, 201510 yr read the codes - real simple, just search for the threads showing the connector above the gas pedal. ground the proper pin and it'll flash the codes. some years - like 95 and 96 have a relay/ABS pump issue. otherwise they're usually simple - just one of the sensors are compromised. there's one sensor at each wheel - they can be dirty/need cleaned or need replaced. with an FSM you could test the values of each ABS sensor via the connectors and a multimeter.
