2003 Baja Tach dead
I pulled the dash today, thinking it might be a loose screw.  No such luck, a large circuit board and everything is soldered in.
Any ideas other than getting a replacement cluster?
I did not see any problems with the circuits.
Everything but the Tach works.
Thanks, Larry
Tacometer and Speedometer are controlled by a separate module inside the cluster. Tachometer signal comes from the ECM I believe, but it has to go into the cluster CPU first. Dunno what kind of signal it is though.
  • 4 weeks later...
Tried a used Tach from a yard.  Same thing.
I'm going to hook up my OBDII computer and see if it has a tach reading.
My OBDII computer has a tach reading, so wiring or I got another failed tach cluster.
Anyone have the FSM wiring from the ECM to gauge cluster?
Thanks, Larry
