Air cond, compressorClutch
I posted before about the clutch (ac) on my 88 GL. Afterward, I finally removed the clutch. I suspected there might be a short causing it to blow fuses. All there is inside is a coil with one wire going to the hot and another grounded. I don't know exactly how to test the coil. I did notice it has a couple if breaks in the insulation. I would really rather use this compressor than try another one as it may not be as good as this one is for pumping etc. All tests I've done, it looks like it may be the coil shorting out. Any input?
Thanks
