January 9, 201610 yr I was installing the Legacy Outback trailing arm frame mounts today. I had lifted a 98 OBS a while ago, that lift was a good training on installing the trailing arm mounts. I lifted my new 2000 OBS and was careful to remove the trailing arm mount bolts by hand (on the 98 the Milwaukee Impact broke 2 of the 6 spot welded mount nuts off inside the frame). The drivers side went well, but the passenger side front mount bolt broke the spot welds on the nuts. I ran the bolt in an out by hand many times spraying it with kroll, but it still let loose. Drilling the hole inside on Saturday to get a socket on the bolt. So it goes. Larry
