February 10, 201610 yr Alright...I have been lurking on this messageboard for about a year trying to figure out an issue my car has been having so I finally signed up. Any help would be much appreciated! So my 99 legacy outback (with 175k miles) has been stalling every time I approach a light or have to idle. When I first start it the idles fine, but the more I come to a stop the idle lowers each time until it dies and the CEL comes on. It pulls the p1507 code for the idle air control valve and a code related to the knock sensor. Now following what I can see other people have done, I pulled the IAC off twice and cleaned it replacing the gasket the first time. I also sea foamed it...no help. Next, I replaced all of the filters and checked for vacuum leaks no luck. After that, I cleaned the MAF sensor really well with MAF cleaner still no luck. Replaced the spark plugs to no avail...any ideas? Originally this problem was intermittent but now it happens every time I drive it.
February 10, 201610 yr Start with a new knock sensor. They fail regularly and are super easy to replace. The $10 ones on ebay do just fine. Second to that, I would check your mass air flow sensor. Clean it and see if that helps. Replace it to be sure. They will cause the car to get buggy, lose power at random and stall out without throwing a code.
February 10, 201610 yr Replace your IAC Get a used one from a junkyard, clean it up and install with new gasket.
February 10, 201610 yr Author I have a new knock sensor on the way luckily so will try that. Thanks for the help!
March 23, 201610 yr Author So I replaced the knock sensor it helped but didn't fix the issue. I just recently ran into someone parting out a 2000 legacy outback are the IAC valves the same or did they change them?
March 23, 201610 yr I apologize if this response double or triple posts, having internet issues. For over a year I had the same issues as you with the same code along with a knock sensor code. It was less frequent though. I replaced the cracked knock sensor but what did the trick was actually replacing the Neutral Safety Switch on the side of my transmission (5spd). From what I understand, that NSS shares the same circuit as the IAC. It makes sense too if its dying when or right after you push in on the clutch if you have one. So I would try that if the IAC doesn't work. Good luck
March 23, 201610 yr Ferret posted this on another thread yesterday:This is a switch on the side of the manual transmission, like the backup light switch. Dealer only item, pretty inexpensive and easy to change. High enough on the trans that you will not leak any fluid. Purpose, , to tell the ECU when you are in Neutral, so either you are decelerating or the ECU must control the Idle. Example, you are driving WITHOUT your foot on the gas, Car in gear, The ECU doesn't have to control the idle. You shift into neutral, NOW the ECU MUST control the idle. It's detected as a fault when the switch is bad ... you are IN GEAR, without foot on the gas, but the ECU DOESN'T KNOW IT, so the ECU now tries to control the idle AND IT CAN'T. So it thinks it's at a HIGH UNCONTROLLABLE IDLE. Older manuals usually call out IAC , TPS and other Idle controls for this error.
March 23, 201610 yr So I replaced the knock sensor it helped but didn't fix the issue. I just recently ran into someone parting out a 2000 legacy outback are the IAC valves the same or did they change them? Nope they are different
March 23, 201610 yr I apologize if this response double or triple posts, having internet issues. For over a year I had the same issues as you with the same code along with a knock sensor code. It was less frequent though. I replaced the cracked knock sensor but what did the trick was actually replacing the Neutral Safety Switch on the side of my transmission (5spd). From what I understand, that NSS shares the same circuit as the IAC. It makes sense too if its dying when or right after you push in on the clutch if you have one. So I would try that if the IAC doesn't work. Good luck That's interesting, definatly something worth looking into. First time I've heard of this problem.
April 14, 20169 yr Author Got a hold of the nss and a buddy let me use his lift swapped it out only got to drive it for a little bit tonight no codes though and it didn't stall. will report back when I have more info. Thanks for the help everybody!
