96 ej22 crankshaft seal
I am pulling my engine tomorrow to replace the clutch and oil separator plate and was wondering if I should replace the rear crankshaft seal or not?
If it's obviously leaking, yes. A little bit of damp grundge around it is normal, but liquid oil is not. Otherwise, leave it alone as it's easy to mis-install the new one and have it leak. Use a metal oil separator plate, plastic ones are junk.
Check the clutch release fork for cracks in the cup that the pivot ball rides in.
