April 23, 20169 yr Having trouble getting the bottom 14mm nut removed that holdes on the starter. There is no access from the top of engine. From underneath the engine there doesnt seem to be enough room to get a socket and ratchet square with the bolt to be able to turn the ratchet. Ive tried a 14mm 3/8 wooble impact with Dewalt impact gun and nut still not loosening. Heated nut with torch also. The nut doesnt look corroded. It seems to be a problem with getting the right angle with wrench. Looking for solution.
April 23, 20169 yr I've usually been able to get them from above with a 6" extension. If there is room a small breaker bar will usually crack it loose. Did have one that I had to go underneath with a 1/2" drive wobble impact adapter on and use a long 1/2" extension and breaker bar, but generally they're not that tight.
April 23, 20169 yr Author Finally got it off with 1/2 IR air wrench with 3/8 wobble socket. My 3/8 Earthquake impact wouldnt budge it.
