June 11, 20169 yr Under the inner tie rod boots, are steering racks usually dry and clean or smeared with greasy wet residue? was gonna install a used xt6 rack. I pulled a inner tie rod boot and the shaft was wet and smeary but not pooled up and the boot was not wet on the outside and showed no leakage. I don't have any others to look at and The other side boot was already removed and cleaned up for storage so that's not a comparison. Im not sure if it was previously leaking or this is normal residual grease. I'm hesitant to install what might be another leaking rack. I haven't paid much attention to how the grease/shaft looks when doing inner tie rod stuff before. XT6's use a golden fluid, not red so color is no aid here. Do I have a 100% chance of leaking or only the standard 50% of a used rack ? Lol
