June 7, 200421 yr I have a 2000 Outback and I am having the clutch judder problem. I had one independent mechanic say he would not do the work because Subaru has not solved the problem and that they keep changing the clutch kits to try and solve the problem. I guess now Subaru recommends as replacement to be a sport clutch and a new flywheel. Anyone had this done? Did it work? How many miles have you driven with the new clutch kit. Any other info? Does anyone know of class action suit against Subaru for this problem or a recall coming down the line? Thanks for all your inputs.
June 9, 200421 yr Had mine done for free here in Oz 6mths after 3yr warranty expired. Fixed the prblem instantly. free clutch slave cylinder too which is another TSB
July 16, 200421 yr Had a new subaru clutch put in my '02 outback wagon a year after I bought it new. Have over 25,000 miles on it and it works like a champ. they fixed the clutch problem starting in the '03 model years. others on this board had similar threads at the time, thank god I found this board at the time. in fact, if you search thru the archives someone posted a copy of a tech bulletin giving all of the new part numbers. i took this bulletin to my dealer and they agreed to replace it under warranty. no longer hate the car, but still wish I had an automatic when I tow my utility trailer. god forbid, we bought a house with a steep driveway later on. RTP373
July 16, 200421 yr I got all the stuff in the bulletin. When it is cold there is still a tiny judder that goes away after the first use. It's not a bad fix and did not require a flywheel on mine.
