Matching tires with no rear drive shaft
Was towing my 98 legacy on a tow dolly across the country. Rear drive shaft pulled. After 2500 miles it threw a rear wheel. Rolled a while before I could get pulled over. It crunched the brake guard into the rotor and ate a chunk off the rotor.
2 questions. With open differential does it matter that the one rotor was locked up for a time while the other spun?
If I keep the drive shaft out, can I run difor rent brand tires on the back until I get a good matched set?
Not at all.  Even an LSD would have probably survived a short incident if you're just referring to the moments around the mishap.
i've done it before and it's fairly commonly done on other open differential situations.  pretty generic in principle so this is probably google material too if needed.
