June 11, 200421 yr I made sure that the tank is full, but when I try to spray the windshield fluid onto the windshield, nothing comes out. Why is that? The wiper blades work, but that's about all. 92 Loyale
June 11, 200421 yr Does anything come out of either one? If not: Disconnect the hose at a joint under the hood and operate the washer button. Anything come out then? Work your way up the line until you find whatever it is that is clogged or not operational. You may be able to apply compressed air to the hose and blow some pressure thru to unclog the tips, thats usually where these go bad.
December 1, 200916 yr Did you end up fixing this? I'm having the same problem. The lines are clear but the pump doesn't come on...I even replaced it with another from the salvage yard. Now what? Is there a fuse for this that may be blown?
December 1, 200916 yr Don't quote me on this, but I think I may have seen a fuse under the dash that controls the circuit on the washer pump. Check under there.
