December 14, 20169 yr My 2006 Outback wagon with auto climate control will blow heat on left and perform correctly. Intermittent heat on right. Have changed passenger actuator motor no change. Can anyone help? I have not had it into dealer to check on board diagnostics.
December 15, 20169 yr It's probably internal to the head unit itself. They, and the radio, are known to have isues with unusual problems. Best bet is to either find yourself a used head unit or Subaru does sell remand units with a core charge. All they need to know is the model number, which is on the trim.
December 15, 20169 yr Heater core. Some 2006's have a recall for too much Chlorine in the coolant, stop in Subaru and see if there's any informaiton on that recall, a TSB, extended warranty, etc....after 10 years I can't imagine there being any warranty but it's worth an ask. You could try flushing but efficacy of that, while variable, is probably limited. Edited December 15, 20169 yr by grossgary
