June 14, 200421 yr Where is the most complete, single source info on swaping out an A/T for a M/T ? I have a 93 loyale 1.8 A/T 3 speed (broke) and an 87 ? wagon w M/T (rusted beyond safety inspection)
June 14, 200421 yr Where is the most complete, single source info on swaping out an A/T for a M/T ? I have a 93 loyale 1.8 A/T 3 speed (broke) and an 87 ? wagon w M/T (rusted beyond safety inspection)This board is the single most complete in depth source of info for swapping trannies. A quick search should yeild some pretty enlightening results.. Lots of us have done it, myself included. Heres one http://www.ultimatesubaru.org/forum/showthread.php?t=15648&highlight=manual+swap Some info about neutral safety switches http://www.ultimatesubaru.org/forum/showthread.php?t=15153&highlight=manual+swap
June 14, 200421 yr its not all in one place, but the search will bring several posts explaining in detail. you should find all you need. "a write-up would be nice" someone could lay out the whole procedure in this post alone. pretty much between both cars you have all you need. however you take one apart is how you will put the other together.
