sethpistol1 Posted June 18, 2004 Share Posted June 18, 2004 my idle runs to high only sometimes other times it runs perfect it's an 1982 wagon and the only thing i can think of is the choke is sticking so how do i fix that? thanks Quote Link to comment Share on other sites More sharing options...
Alaska Brat Posted June 18, 2004 Share Posted June 18, 2004 my idle runs to high only sometimes other times it runs perfect it's an 1982 wagon and the only thing i can think of is the choke is sticking so how do i fix that?thanks Make sure the choke is getting power. Most 82's had Carter carberators and if you are not getting power to the choke and its a Carter carberator check the fuses and the coolant temp sensor on the intake manifold. Or the carberator screws are loose and need to be tightened from the bottom side of the carberator and the carberator needs to be removed for those screws to be tightened. hope that helps you out buddy. Karen Boston Quote Link to comment Share on other sites More sharing options...
