Front wheel bearing replacement Legacy
Can any one give an aftermarket part number for a front bearing on a 92 awd legacy(and approx cost) , also is there any trick to changing them ?
Check 1stsubaruparts.com for the cost of a Subaru bearing and then look at Auto Zone, Advance Auto Parts, etc. They usually say who the manufacturer is and give the manufacturers part number. Can probably get the same thing at a parts house down under.
Need to have a Hub Tamer or take off the hub to have the bearing pressed out some place.
Good luck.
