1982 brat won’t start.
Hi I’m building a brat for senior project and I am new to this. I bought the truck for 600$ The motor had water in heads. so yesterday pulled the motor and put all new seals in it. Head gasket,oil pan extra. Bolted it back into its home and connect everything as far as I can tell but now all I have are headlights and a horn. No wonderful tong noise from ignition no lights no fan blower no nothin just a horn and headlights? I checked the fuses inside but now I’m lost???? It did turn over when I first got it but didn’t start due to water in cylinders.
Check the fusible links in the box near the battery.
That was it thanks.
Naru do you know what his is?
It has a wire,right?
I think that is "Solenoid valve #1"
It controls the air suction valve.
