I have a 92 loyal drive to Walmart shut it off went to start and nothing
I went in the store came out and tried to start it and nothing like battery was dead brand new fullky charged battery with ignition on I get no heater fan no head lights like I have no power checked grounds ok jumped solinoid it cranks but no fire probably becuase switch isn't working but I don't know
Loose battery cable or blown fusible link. Links should be in a small box near the battery.
I checked fusible links battery cables ground ECT bypass Solonoid and it grandma but it's like not getting fire or fuel so ignition is not switching power on tested ignition ok found bad growing at PCM brain and pushed it back and tighteed up all lights work again and it fixed right up what a tricky little bigger
