86 GL 4dr
Hey i have a 86 GL 4d with a EA-82 carb with ECU
I"m getting code 22 and code 24 and it wont idle at all and it stumbles really bad is there any suggestions on how to fix those codes??
The code 22 is speed sensor related. the factory rundown on testing it is rather crazy so I wont try to confuse you with it.
the code 24 is for the temp sensor. I would suspect this as your problem area.
I really dont know how the computer controled carbs work on a sube verry well so I will refrain from guessing.
of course you have checked all the basics like fuses and good clean grounds(to the motor too)?
