Customized Swing Arms
So I'm considering building my BRAT with new swing arms / A.
I'm going to widen the position a little (less than an inch so as not to mess too much with axles) to add some extra adjustment points for camber and caster and perhaps adjust the lower spindle mount to allow a better / sturdier ball joint mount.
Once I draw it, I'll get a picture up.
I'll probably use the mounts in the factory so that bushings don't change or I can go with an upgraded bushing design.
It's based on what I can easily get.
Any suggestions before I draw?where am i 192.168.8.1 192.168.100.1
Edited by chris1
Check Whiteline for parts that may fit - much less expensive and less hassle than rolling your own.
