November 15, 20214 yr I need to replace the driveshaft due to a squeaking u-joint, and need to confirm which transmission I have. All I can find on the internet is that the 4 speed was used in the EJ25 cars and the 5 speed was used in the 6 cylinder cars. Is this the case, or is there some other way to identify with certainty which transmission is in the car before I order a driveshaft. Thanks!
November 15, 20214 yr 55 minutes ago, ebbsspeed said: I need to replace the driveshaft due to a squeaking u-joint, and need to confirm which transmission I have. All I can find on the internet is that the 4 speed was used in the EJ25 cars and the 5 speed was used in the 6 cylinder cars. Is this the case, or is there some other way to identify with certainty which transmission is in the car before I order a driveshaft. Thanks! Yours is definitely a 4 speed automatic. All 1990-2009 4 cylinder Subaru Legacy outback Forester Impreza non turbo (and most or all turbos) automatics are the same 4EAT (4 speed) automatic trans. Though there were a few minor changes over the years.
November 16, 20214 yr 7 hours ago, ebbsspeed said: Thanks @idosubaru! I appreciate the confirmation of what I suspected. You’re welcome. Good luck, hope that shaft takes care of the issues.
