February 17, 20224 yr I have a 2022 Outback and really wish I could shut the seatbelt chime off. Other than plugging in the seatbelt and sitting on top of it, can it be disabled? I know I can do that in my older one ton Dodge diesel and it really comes in handy at times.
February 17, 20224 yr Can do. Turn the key in the ignition to "on", the spot just before starting the engine. Buckle and unbuckle the seatbelt 20 times within 30 seconds. Immediately take the key out of the ignition. Enjoy your chime-less Subaru Edit: you only have to do this once and the chime is off for good. Unless your battery dies. Also, you can toggle the chime on/off by following the same instructions. Edited February 17, 20224 yr by brus brother
