April 27, 20223 yr Hello fella subi's.. I have a 2003 Baja with 73K no rust .. just had to have the trans rebuilt and I am told there is a pully wobble50 around the engine...maybe causing the steering wheel to shake at 50mph and above... anyone have suggestions for me to have checked out? I am not a mechanic and need to rely on others
April 28, 20223 yr many possibilities for a 20 year-old car to have several areas needing attention. If someone saw a pulley wobble, which one? Or, did they mean the crank pulley is separating? stuck brake caliper, bad lower control arm bushing, worn tie rods,...etc.You need to find a Subaru-friendly shop and have them check it out. also, when was the last timing belt system service? I know miles are low, but the schedule also says 105 MONTHS. Edited April 28, 20223 yr by 1 Lucky Texan
