connecting Igniter, ignition coil and distributor
EA82T Ignition components
kindly this is my EA82T ignition section which has been messed up, I am trying to reconnect the wires from the module. There is the Blue and Black/white wire pair towards the distributor, and the Black white Wire and Black red pair directly under the ignition coil. The car is Subaru Leone 1.8T 1987 model, and the wiring diagram isn't clear on this Thanks edsaisam@yahoo.com
Models can be confused when just using year as description due to post 31July each year becoming the Model Year MY for the following year. Do you also have a month of 1987 when yours was built? I have some diagrams, I also have an April 1987 EA82T I could look at to help interpret what you need
thanks, I will appreciate your help, especially with wires and pins/ connectors from the ignition module to the ignition coil and from the module to Ecu.
i am confused on your "module" - do you mean the wires between the distributor and coil ? Mine has an item close to or part of the coil bracket , called ignitor
sorry about the use of words and thanks, I believe the Ignition control module (ICM) and igniter refer to the same thing. My car Vin AL7.011866 is an 87 model, the igniter is on the coil bracket, so I believe the system should basically be the same with little variation. I need (1) to identify the pulse wire from the control unit under the steering to the igniter at the coil.(2) the wires from the ignition coil to the igniter and tachometer.
yes those, and particularly the one that conducts the signal from the engine control unit to the ignition or igniter
In the diagram for the coil, there is no igniter shown or referred to, from memory it is all attached ?
for 87 USDM XT, may not be same as non XT !!!!!!!!!!
Lucky for some, there are only four wires at the coil, and two are BW
The pair that are WY and BW
WY goes to WY at ECU. Two wires both WY at ECU, pins 37 & 43
BW to BW at ECU pin 19
The pair that are BW and plain old Y
The BW goes to (radio?) condensor which has a B grounding wire also
The Y of this pair goes to the tacho in the dash cluster. Y all the way to dash pins by the looks
Edited by Steptoe's photos
now, due to the complex differences in wiring of the distributor of the 1987 models, there was a change mid year, can you look at the part number cast into the side of your distributor ? I think the first part may be 22100 AA , and the variation is in the last three digits. I am expecting either 410 or 450 , yet also prepared for something close ....
I am starting to wonder what version of three or four EA82T you have there.
Does your distributor have a vacuum advance canister on the side? That would make it Series 1 (1985, 1986 models in several countries)
Flapper style air flow meter (series 1)
or hotwire , cylindrical air flow meter (series 2 flat manifold, series 3 spider manifold)
  • 3 weeks later...
  • 5 months later...
hello Steptoe sorry I shelved the recovery of my Subaru to work on another project out of town. am now back
This is a Subaru leone 1.8  turbo EA82T engine.  The ECM is four plug. Rats chewed up wires and pipes around the Distributor,the
ignition coil, and the igniter. I need help identifying which wire connects which terminal so I can crank the engine. much thanks
my distributor is xxxx450 it does not have the vacuum advance unit
my ecm is 4 plug
OK. I have not looked in here for some time myself. There are two part numbers for four plug ECU and no vacuum unit due to optical system inside and ECU takes control of the spark advance and retard. I do have some diagrams for the US EA82T in the XT, so likely the same for it and any other 4 plug ECU equipped mpfi (which USDM may not have got many, other than in XT4. I will try to get back to you and your rats, in good time
OK, worked out I have already supplied diagram and description for the coil. Have they been checked and confirmed as OK?
It might help if you can describe each plug and list number of wires and use the colour codes to identify them, where you are stuck.
 I am most grateful. As for the rats I have biologically allowed a control and eliminate friend to represenent me and the subie called Mr cat. thanks
the coil is tested okay, . May know where you sent the diagrams please
thanks will asap.
It will take a hungry and bored cat to actually detain a rat from what my hoarder mate has experienced. Rat poison baits do not need to be fed at all :)
It has taken me a while to accept that Subaru 1987 do not call the distributor as such in their diagrams for wiring.
The wiring all refers to the duty of a crank angle sensor.
My diagrams show black, round connector of four wires.
Red goes to ECU 7 which is also red at the ECU end
Black goes to ECU8 which is also black at ECU end
White goes to ECU 17 which is also white at ECU end
Black/red trace goes to ECU 10,20 and 30 if ATrans looks to be the main grounding connection for ECU and all it's sensors and for shielding wire grounding - grounding is preferable to be grounded at ECU says an electrical engineeer friend
Thank you, very clear am most grateful.
Kindly similarly illustrate wires to the igniter and the ignition coil
as I have several wires whose destination is not clear. Am attaching pictures
for clarity.
Also find attached a unit under the front left side seat, I don't seem to know it neither its function.
for clarity.
on the ECM which is pin 1 and what is the order. Thank you
diagram posted here in this post April 17th up there
box under seat would be air suspension if you have that, or windows, but not usually affect engine. No idea if you have 4 speed auto - it has a brain box somehwere
if i quote this, it may show up included diagram as a latest post ??
