July 26, 200421 yr Does anyone know how much it should cost to repair the computer in a 2003 Baja? Thanks in advance
July 26, 200421 yr I can't help with a price but ECU's can run over $600 dollars from a dealer. The ECU's are normally very reliable. Are you sure it is bad? Even if it is bad, the unit should be under warranty unless someone damaged it somehow.
