9i Legacy Coolant Sensor?
in my car the electric rad fans come on as soon as i start car and stay on also on start it runs real rough do you think it could be sensor? a/c is not turned on when this happens
Thnx, Mark
have you checked the codes? But yeah...sort of sounds like a coolant temp sensor.
Yes I agree with Josh
Depending on how the coolant temerature sensor fails . If after checking the codes you disconnect the battery for say 30 minutes this should reset the alarms. The fans may then not turn on at start depending on how the alarm is processed.
My guess is that you have had the check engine light up sveral times and not taken any action so after say 5 or 10 such events the ECU has latched the fans up
ok im gonna go with the coolant sensor, now one question? where is it? i see a sensor under alternator but it only has 1 lead, i asume thats for the gauge and not the computer sensor? this is on a ej22 engine
Thnx Again, Mark
theres no senor in the rad, the sensor you're looking for is at the top of the water manifold under the intake manifold. Theres actually two of em, i forget which is which.
Thnx for the replys, my engine is mpfi and i dont see anything like whats in the pics Josh, any other hints?
Thnx, Mark
:) :) Thanks Everyone, that did the trick Mark
