August 9, 200421 yr Hello, new to the forums... I'm wondering if someone can tell me the clearance between frame rails on an XT and/or a GL of this generation: http://www.cardomain.com/memberpage/303519/2 Just need to know about how much space there is between the frame rails in the engine bay to check on engine swap possibilities. If someone could, say, tape a yardstick to the frame rail on each side and measure across, it would be very much appreciated. Also, the useable clearance between the firewall and radiator would be great to know. Thanks, Mike
