found something that doesn't look factory need help identifying
gros ventre
I only see one wire tapped from the main harness.  can you trace blue/pink wire and see if it runs into the ignition switch?
guessing it's a breathalyzer module that needs breathing into to start the car.
  • 4 weeks later...
That's an aftermarket anti-theft module that takes a "key" that's a little flat thing that looks like it goes to a treadmill or something.  The correct repair, as you already found, is to toss it in the bin and put the wiring back to stock.
